cat removal for extra power?
Postby dnalunchie » Fri May 17, 2013 7:51 pm
A mate of mine up north just brought a new car (V8 sti), I know what a bastard right.
Anyway he is getting its ecu remapped for more power but was also suggesting removing the catalytic converters in the exhaust and replacing them with steel sections of pipe. Reason for this over a full exhaust is that he doesn't want to make it more noisy if possible.
Do you guys reckon this would liberate more power or not?
Current: 90 3sfe Corona
dnalunchie
Postby Stott69 » Fri May 17, 2013 8:27 pm
Not unless they have colapsed or blocked. Been covered a few times on here I think?
Stott69
Postby dnalunchie » Fri May 17, 2013 8:32 pm
Stott69 wrote:Not unless they have colapsed or blocked. Been covered a few times on here I think?
oh? wouldn't have thought that, would have thought they are quite restrictive
dnalunchie
Postby Makaveli » Fri May 17, 2013 8:49 pm
Cat Converter restricts exhaust gas flow. It's not a huge difference. But it does make a difference. Maybe 20-30hp? Maybe with stock turbo the difference is slightly less.
Makaveli
Postby ee904age » Fri May 17, 2013 8:52 pm
Makaveli wrote: It's not a huge difference. But it does make a difference. Maybe 20-30hp? .
So around 10% !?!?! Seems a fairly big difference to me...
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby dnalunchie » Fri May 17, 2013 8:58 pm
at first I would have told him just to do the whole exhaust but after living with my flatmates stock v6 RA for the last year I was surprised by how loud a stock sti exhaust really is
dnalunchie
Postby Lloyd » Fri May 17, 2013 9:57 pm
A cat restricts flow. A muffler restricts flow. Every exhaust bend restricts flow.
By how much is what matters. And in reality, it's very little.
Postby rollaholic » Fri May 17, 2013 10:42 pm
dnalunchie wrote:at first I would have told him just to do the whole exhaust but after living with my flatmates stock v6 RA for the last year I was surprised by how loud a stock sti exhaust really is
exhaust on our v5 is completely stock apart from deleted cat (not me)
its quiet as $&#$%. (i like that)
get them to dyno before and after cat for final say imo
Postby RomanV » Sat May 18, 2013 12:30 am
rollaholic wrote:get them to dyno before and after cat for final say imo
Yep I did that (on an NA car though) for zero difference. Obviously depends on case by case basis however.
Just leave it as is.
Postby dnalunchie » Sat May 18, 2013 12:34 am
Maybe his is louder since it is an RA. Bigger pipes maybe
dnalunchie
Postby stoffa » Sat May 18, 2013 8:20 am
having come from WRX ownership it definately makes a difference, but worth replacing the whole downpipe with a Rage one on those twin scroll turbo's.
stoffa
Postby rollaholic » Sat May 18, 2013 3:01 pm
RA doesnt get more power, just less weight AFAIK. plus tricks like DCCD or w/e
Postby tiny2009 » Sun May 19, 2013 10:15 am
Replaced cat in the Runx with a resonator, felt ever sop slightly slightly better in lower RPM, also resonator made it sound the same. No proof that its actually better however it was removed due to smelling like Rotorua so was possibly blocked? Kept the cat and sold it to scrappies, so cost to get it replaced wasn't much.
Did the same with the JZX110, the 1JZ felt much better in mid range after.
EDIT: Dyno shows before (red) and after cat removed (blue):
tiny2009
Postby Mr Revhead » Sun May 19, 2013 10:42 am
What year is a V 8 and what are the applicable cat laws for it?
Postby thegreatestben » Sun May 19, 2013 12:16 pm
Also have to consider that none of these cars are what would be considered as "new" and as such the Cat would be far from it too. Might be a very little in it if you dyno'd them before and after out of the showroom.
thegreatestben
Postby Heylin » Tue May 21, 2013 1:27 pm
Not sure how they vary to the 2004 Legacy GT, but the order of gains for the Legacy are
- dump pipe \ front pipe which includes cats
- mid cat
- mufflers
Complimented by a remap \ tune at the end.
Heylin
Heylin
Postby dnalunchie » Tue May 21, 2013 2:38 pm
Mr Revhead wrote:What year is a V 8 and what are the applicable cat laws for it?
2003
dnalunchie
Postby rollaholic » Tue May 21, 2013 6:38 pm
Heylin wrote:Not sure how they vary to the 2004 Legacy GT, but the order of gains for the Legacy are
- mid cat
- mufflers
i'd imagine the cats are mainly included here cos they are part of the front pipe, and its cheaper not to re-use / fit new ones.
but i might be wrong?
