Help with silvertop power steering belt
Postby vr4boy » Sun May 19, 2013 8:39 pm
Does anyone know what size belt needed when a/c is removed and there is no longer a tensioner?
1995 ae101 levin st 20v
vr4boy
Postby whynot » Sun May 19, 2013 9:20 pm
5pk875 is what I use on mine
whynot
Postby vr4boy » Sun May 19, 2013 9:35 pm
So I'm guessing you put the belt on the bolt the pump on to tension it?
vr4boy
Postby ch4ng » Sun May 19, 2013 11:45 pm
5PK875
Note: this is SO much easier if your radiator is out of the car.
Remove the power steering fluid reservoir out of its holder.
Unbolt power steering pump. Short mounting bolt and one that goes through the pulley IIRC
Fit the belt around the pulleys
Use an short pry bar (~25cm) to lever the pump into position while you start the thread on the long bolt with a 1/4" ratchet
GLHF
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby vr4boy » Mon May 20, 2013 6:30 pm
Thanks for the help guys, got the belt and fitted it today, was really easy. Radiator was already out and p/s was to, put the belt over the pulleys and pulled the pump across till one bolt lined up and then it was rather easy, had pump already on bracket when I did it, and just bolted the hole lot on in one go.
vr4boy
Users browsing this forum: Google [Bot] and 42 guests
