Urgent help please - rapid coolant loss Cynos B
Postby markoneswift » Wed Jun 12, 2013 8:59 pm
Hi all, I posted earlier about temps not rising and heater output poor on my Cynos B. After filling up at the garage today, I noticed a puddle of coolant under the car - not good !!!
I've checked my radiator for visible leaks and the top / bottom hoses but they all look good. There is a quantity of water, however, dripping down from the back of the engine compartment and evaporating on the exhaust pipe as it passes underneath. Obviously not good for cooling, or for the exhaust because it's rusting.
I have checked the hose from the thermostat housing to the heater inlet and it seems good and gets hot. The return hose, however, doesn't seem to get hot and is very brittle. I think this hose may have perished but it's awkwarde to see as it passes down the back of the engine - where does this hose connect back to ? It looks to go under the engine near the timing cover ??? Anyone got any other ideas why I am suffering coolant loss from somewhere at the back of the engine bay ?? Thanks all !
markoneswift
Postby RobertC » Wed Jun 12, 2013 9:57 pm
looking from the front the waterpump is on the back left.
there is a pipe running from the water pump to a rubber hose connecting to the back of the thermostat housing.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby markoneswift » Wed Jun 12, 2013 10:31 pm
Thanks RobertC - back left eh ? Well that seems a likely area where the leak is coming from - thanks for that.
markoneswift
Postby markoneswift » Fri Jun 14, 2013 10:57 am
UPDATE - the local garage have found a leak in both the pipe AND the hose that link the water pump to the back of the thermostat housing. I have aksed them to replace both and check the thermostat opeartion at the same time.
markoneswift
Postby B1NZ » Fri Jun 14, 2013 6:28 pm
There was a similar pipe on my smallport 4AGE in my parts car that spung the same sort of leak
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby markoneswift » Sun Jun 16, 2013 7:18 pm
Another update - pipes / hoses replaced / repaired and a sealing O ring replaced. Topped up with 50/50 by the garage who did the reapir and now we're all good again :-)
markoneswift
Users browsing this forum: Google [Bot] and 43 guests
