Shortest toyota oil filter
Postby KinLoud » Tue Jun 18, 2013 1:00 pm
Tried TS search and google
Looking for a shorter oil filter than standard 4age one (for example)
I'd thought it was a 1uz filter but maybe I'm wrong
Any comments? Pics?
Thanks
Ken
Postby 1I1 » Tue Jun 18, 2013 1:58 pm
Slightly shorter than the 4AGE one is a 90915-10003
TRD Clicky >>Here
1I1
Postby KinLoud » Tue Jun 18, 2013 2:14 pm
Thanks Mark
Seems it only fits 1 or 2 cars (jokes!)
http://www.toyodiy.com/parts/xref?s=909 ... J=on&mG=on
Do you have one in stock to measure?
Thanks
Ken
Postby sergei » Tue Jun 18, 2013 2:15 pm
this might help:
http://infodozer.com/catalogs/filters-u ... 0915-10001
shortest I found that will 100% fit is 90915-10001
the shortest that might fit is 15601-87204
http://infodozer.com/catalogs/filters-u ... 5601-87204
Edit: it looks like 90195-10001 is identical to 90915-10003 ....
Postby THA SHZ » Tue Jun 18, 2013 3:28 pm
ken why not put in a remote then ?
THA SHZ
Postby gt4dude » Tue Jun 18, 2013 7:07 pm
10002/10004 for 3SGT/4AG (Ryco Z432)
10001/10003 is the shorter 3SGE filter (Z386)
the later numbers supercede the earlier numbers
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Mr Revhead » Tue Jun 18, 2013 7:44 pm
gt4dude wrote:10002/10004 for 3SGT/4AG (Ryco Z432)
All those are the same fitment. 90915-10003 is the smallest Toyota one.
Go have a look at Daihatsu. They did a tiny one that might share the same fitment
Postby kim0663 » Wed Jun 19, 2013 1:23 am
The oil filter from a daihatsu copen turbo was ridiculously short (for good reason on that car too)?
Mr2 GT-S
330ci M
kim0663
Postby KinLoud » Wed Jun 19, 2013 9:14 am
4agte for my AA63 Carina racecar
Will run an oil cooler but don't want to use a remote filter unless I really have to.
Filter direct onto sandwich plate is simpler, takes up less room, less plumbing etc.
Standard filter has 6mm clearance from exhaust manifold (evilSi)
More clearance plus a bit of heat shielding around exhaust runner should be sweet
Postby 1I1 » Wed Jun 19, 2013 1:02 pm
Like revvy mentioned theres the Daihatsu option which is roughly 66mm tall (15601-97202) vs the Toyota one roughly 73mm (90915-10003).
And the 4AGE filter at roughly 88mm
TRD Clicky >>Here
1I1
Postby KinLoud » Wed Jun 19, 2013 4:19 pm
Thanks everyone
Bought the Daihatsu option (15601-97202)
Will see if it will work with my sandwich plate.
The threaded portion goes into the filter base rather than sticking out...
So will see if there is enough length of thread to engage the filter properly
Will post my progress
Ken
Users browsing this forum: Google [Bot] and 44 guests
