Scratchy noise when turning? Altezza RS200 3S-GE
Postby Tagged » Fri Jun 28, 2013 9:12 pm
Thought I'd just update an old post instead of starting a new one to save the server some tiny load :D
The RS200 I've bought off my friend started having this scratchy noise when turning. It doesn't happen straight away when I start turning, instead it happens when the turning angle is over a certain degrees.
Anyone had similar experience??
Thanks
----- Below is the old post if -------
Just bought a RS200 off a friend and took it for a service today.
After the service I noticed this slushy sound coming from behind the dash when idle, and when the pedal is down the sound becomes more intense for about one or two seconds. The sound could be described like a mix of liquid and air rushing through some pipe.
I had a look on the internet and it seems I would either need to clean my heater core or there is air in my radiator. I couldn't really think of anything the service guys could have done which would cause this issue, except for topping up the coolant.
So I just wanna ask what should I so at this point?? Is this a serious issue that would cause larger problems in the future?
I was also told that I should do the following to try and bleed the radiator;
1. Take off the radiator lid
2. Start up the car
3. Turn the heater on max power at the highest temp
4. Let it idle for 20min
Can someone explain how would this bleed the radiator?
Thanks guys!
Tagged
Postby Insighttech » Fri Jun 28, 2013 9:34 pm
That is right. But don't turn the speed of the fan on. Wait till the radiator fan starts up and put the radiator cap back on. This ensures the thermostat is open and the water is circulating. Make sure the AC is also off. Are you also running coolant or water? Condition of the fluid?
Insighttech
Postby GTTpower » Fri Jun 28, 2013 9:46 pm
Yeah most Altezza's get this. That method works. I still have to do it every so often.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Re: Altezza RS200 3S-GE. Radiator or Heater Core problem??
Postby allencr » Fri Jun 28, 2013 10:55 pm
It needs the heater valve open and the engine's thermostat to start opening to get circulation. Once the thermostat opens a bit, every bit of air is pushed to the highest point, the radiator, when the rpm's are over 2000 for about 15 seconds, and that's as much 'bleeding' as it would ever need.
Just drive it. Check & top up rad. & overflow afterwards, that's it
Nothing ever needs to idle for 20 minutes.
allencr
Postby Tagged » Fri Jun 28, 2013 11:17 pm
thanks for the replies guys :)
Tagged
Users browsing this forum: Bing [Bot], Google [Bot] and 38 guests
