Axle studs with bushing ??
Postby jondee86 » Wed Jul 10, 2013 7:36 pm
Was looking at a "pair" of AE86 zenki axles I bought of tardme
a while ago. They have the big bearings and look legit, but when
I went to take the studs out I found that one axle had bushings
for the studs. The studs were 12 x 1.5 and close enough to the
standard length. But on one axle the holes were bushed down
to approx 12 dia. So studs with a 12mm knurl instead of the
standard 14mm knurl ??
Anyone struck this before ? Any reason why it would be done other
than running out of 14mm knurl studs for a repair ?
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby jondee86 » Thu Jul 11, 2013 9:31 pm
Bushings looked a bit like this...
Fitted from the axle side of the flange, and then the stud pressed
into the bushing.
Cheers... jondee86
jondee86
Postby Dell'Orto » Thu Jul 11, 2013 9:46 pm
Weird. Can only think that perhaps the holes were ovaled, so they sleeved them down?
Postby wde_bdy » Thu Jul 11, 2013 9:59 pm
Only reason to do it would be rooted holes from studs spinning or too many stud replacements. Replace axles or just run with the spacers.
Callum
wde_bdy
