lowering hiace 05' onwards
Postby 92mr2paddy » Sat Jul 13, 2013 8:12 pm
wanting to lower my hiace by 3inch, only problem i havent been able to find any 3inch blocks and some people have said i have to get leafs cold rolled etc etc, anyone had this done or know of a good shop that can do this, in auckland area,
any help be good, cheers.
92mr2paddy
Postby Grrrrrrr! » Sat Jul 13, 2013 8:22 pm
Probably because more than two inches is cert territory.
Grrrrrrr!
Postby 92mr2paddy » Sat Jul 13, 2013 8:37 pm
doesnt mean it can't be done...
92mr2paddy
Postby Grrrrrrr! » Sat Jul 13, 2013 8:44 pm
True, but you need lift bars and anti-tramp rods.. seems like a lot of hassle.
2.3(18) Spacer blocks which have been fitted to leaf spring suspension
systems to raise or lower the ride height of the vehicle must be of
a depth no greater than:
(a) 50 mm if not supported by lift-bars or anti-tramp rods; or
(b) if supported by correctly fitted and adjusted lift-bars or
anti-tramp rods, 80 mm.
Grrrrrrr!
Postby wde_bdy » Sat Jul 13, 2013 9:00 pm
In theory, any heat applied to springs requires cert. If you can get leaves cold rolled to a bit lower and run 2 inch blocks as well as keeping enough travel from factory bumpstops then you are sweet. Haven't looked under a late model Hiace for a while, expect 3 inches without cert worthy mods is going to be a bit hard to do though.
Callum
wde_bdy
Postby 92mr2paddy » Sat Jul 13, 2013 9:23 pm
just been talking to a mate and he's had his lowered the usual 50mm and he says it hits the bumpstops pretty easy so they will have to be moddified removed if going any lower.. he's not a car guy so couldnt tell me anymore info but the place he got it done don't do anything other than simple bolt-in off the shelf stuff so no point going there.
92mr2paddy
Postby wde_bdy » Sat Jul 13, 2013 9:29 pm
That would confirm it needs cert if you want to go past 50mm and keep it legal. Work out how far you want to go then cut what you need to to get there.
Callum
wde_bdy
Postby 92mr2paddy » Sat Jul 13, 2013 10:05 pm
yea if it needs a cert that's not a problem, just need to find a place that can do the work..
92mr2paddy
Postby tsoob » Sun Jul 14, 2013 4:00 pm
Hi,
Come see us mate have lowered heaps of them
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Users browsing this forum: Google [Bot] and 49 guests
