4age B/T 20V Dizzy Configuaration for Link G4
Postby tsoob » Sun Jul 14, 2013 3:59 pm
hey team..
Who is currently running a 20v head with a later link g4..?
What dizzy are you using? The link is not liking the factory one at all..
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby DexGT » Sun Jul 14, 2013 4:16 pm
When I upgraded to the G4 on the starlet I fitted coil on plug(COP) so no dizzy needed , I did keep the base of the dizzy for the pulse/ reset for the timing 8).
I found a place in oz that makes a plate to fit COP to 20v ,actually they make a few bits you might like, have a look http://s-86.com/parts.php
I turned the cap down and made a inset to tidy it up
DexGT
Postby matt dunn » Sun Jul 14, 2013 5:21 pm
Does not matter if you run the base or the whole thing the settings are ther same for the triggers.
The 20V dist should work perfect on the G4.
Mine does and so does all the other one'si have seen.
Either you have a wiring issue or a trigger setting issue in the program,
or a dud dist.
How have you wired it?
http://www.linkecu.com/support/document ... 4Tooth.pdf
Postby QikStarlie » Sun Jul 14, 2013 5:41 pm
as above 20v stuff works perfect with link. its the same 24tooth and sync setup, as 16v smallport and heaps of other toyota's run.
QikStarlie
Postby TRD_ZERO » Sun Jul 14, 2013 6:59 pm
yeah I run a link g4 atom on my bt and it works fine on the factory dizzy.
Previous:
TRD_ZERO
Postby tsoob » Wed Jul 24, 2013 3:22 pm
ECU was set to crank not cas for the pickup.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Users browsing this forum: Google [Bot] and 45 guests
