rwd 20v leads with Evo coils
Postby ryanfels » Mon Jul 22, 2013 12:33 pm
Hey guys
Im doing a rwd 20v conversion into my aa63 and im using 4g63 wasted spark coils. Is there any off the shelf leads i can use with them? Im pretty open to mounting the coils where ever i need to (firewall would be ideal)
Or is custom the only way to go? (im trying to avoid this as i need the car going by next week and im a little tight on cash)
Thanks
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby limbo » Mon Jul 22, 2013 3:26 pm
Not quite what your are asking but another option if you want to do away with plug leads all together
http://s-86.com/coilpackplate.php
limbo
Postby QikStarlie » Mon Jul 22, 2013 7:29 pm
can use some of those 5 dollar bosch ones from supercheap to get you going.
QikStarlie
Postby ryanfels » Tue Jul 23, 2013 8:35 am
QikStarlie wrote:can use some of those 5 dollar bosch ones from supercheap to get you going.
I did think of that but dont they need to have the boot on them to seal the on the rocker cover?
ryanfels
Postby xsspeed » Tue Jul 23, 2013 9:12 am
long term probably better to, but its only really there to keep oil/water/crap out of the spark plug hole
Postby lorolla24 » Tue Jul 23, 2013 5:59 pm
I got a custom set made by MRP for $160.
Included tubes and 8mm cable to suit 20v head.
Ke35 20v turbo - 200kw atw 13psi
13.5@169km
lorolla24
Postby Distrb » Tue Jul 23, 2013 11:12 pm
Depends where you are mounting the coils but I used off the shelf top gun leads for a Suzuki baleno. Had both the correct ends
Distrb
Regular Poster
Postby ryanfels » Wed Jul 24, 2013 9:39 am
Distrb wrote:Depends where you are mounting the coils but I used off the shelf top gun leads for a Suzuki baleno. Had both the correct ends
I was hoping to mount them to the firewall, just above where the dizzy now sits
ryanfels
Postby Stu- » Thu Jul 25, 2013 9:51 am
$8 eagle leads from Appco etc FTW.
Just measure with string and go from there, you can cut and adapt the covers off the stock leads to plug the top of the tubes with a bit of glue if you need.
Project Thread
Stu-
Postby ryanfels » Thu Jul 25, 2013 10:09 am
Hmmm, i do like using 2 pot glue
ryanfels
Users browsing this forum: Bing [Bot] and 49 guests
