Weird 1MZ-FE issue - low idle on incline
Postby KiwiMR2 » Fri Jul 26, 2013 9:21 pm
.....but only with front end up. Directly after this comes knock even with the slightest load.
So can pull into driveway (incline with engine up) and turn off car, go inside, come out later (anytime) & start the car & the idle is low, can hear a bit if sputtering from exhaust if you listen & knock when driving off. Park on flats 5 mins later, turn off & come back 30 mins later & runs fine.
Have tried pulling into incline location & sat listening to engine etc. & virtually instantly it starts. Can DRIVE up an incline & not notice it & have reversed into same incline location & no issue.
So basically only with engine up.
Fuel filter is fine....fuel pump on way out?
Andy
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby BBBrad » Fri Jul 26, 2013 10:57 pm
Just a stab in the dark here, but has it got a non return fuel system? If so, Could it be heat from the engine boiling the fuel in the fuel rail etc (while sitting), and then because of the engine end up, vapour trapped in the rail when engine started? Just a quess.
My new car...99 mr-s
BBBrad
Postby thegreatestben » Sat Jul 27, 2013 1:26 am
Coolant level correct?
thegreatestben
Postby KiwiMR2 » Sat Jul 27, 2013 11:04 am
Morning
Not sure about the fuels system....what type it has, coolant is fine I think, will check though. Why do you think that might cause it?
Andy
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby kim0663 » Mon Jul 29, 2013 7:26 pm
Kinda stating the obvious but got enough fuel in them fuel tank? ie: would it still do it with 20L+ in the fuel tank?
Mr2 GT-S
330ci M
kim0663
Users browsing this forum: Bing [Bot] and 41 guests
