tyre width
tyre width
Postby Stott69 » Sun Jul 28, 2013 4:10 pm
Whats the widest tyre you can/should fit to a 7" rim?
Stott69
Postby Grrrrrrr! » Sun Jul 28, 2013 4:15 pm
Grrrrrrr!
Postby RobertC » Sun Jul 28, 2013 4:21 pm
Have a look at this.
http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2009_V2_Tyre_Size_to_Wheel_Size_Compatibility_Guide.pdf
Depends a bit on the profile and diameter.
also have a look at this for what a tyre company recommends
http://www.toyo.co.nz/tyre_detail.php?T_name=Proxes%20T1R
Are you asking form a performance or aesthetic or purely a safety point of view?
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby touge_ae101 » Sun Jul 28, 2013 6:09 pm
205 is the ideal tyre width for a 7" rim. 215 is doable as well but anything up to 225 etc is just yuck.
also you'll note that some tyre companies 'sizes' are slightly different. i.e. a falken 205 and hankook 205 probably won't be the same size. this is due to the different shapes of the mold the tyre is made into etc.
touge_ae101
Postby Dell'Orto » Sun Jul 28, 2013 6:14 pm
You often used to see 235's jammed on old 7" wide hotwires, and they look balloony as $&#$%. I wouldn't go wider than a 205 personally. 195's look good ;)
Postby Stott69 » Sun Jul 28, 2013 6:15 pm
Mainly the safty and legal side of things. Side wall will be what ever to match factory roollind diameter. That lvvta sheet gives you a fair bit of buldge dont they?
Rims are 17x7. Factory is a 16/60/225 I think
Stott69
Postby Dell'Orto » Sun Jul 28, 2013 6:30 pm
They would have been 8's factory no? My series 4 RX-7 had 225/50/16's on 8" wide rims, 60 profile would be comical
Postby Stott69 » Sun Jul 28, 2013 6:48 pm
Its the spare I was looking at for that size. Its a 16x7.5 factory on the aristo isnt that wide realy. Possible a upsized spare to work with the 19"s too
Stott69
Postby Stott69 » Sun Jul 28, 2013 11:33 pm
Just checked factory specs should be 225/55/16.
Stott69
Users browsing this forum: No registered users and 40 guests
