Soft Struts?
Soft Struts?
Postby mcfatty1000 » Wed Aug 28, 2013 5:13 pm
Ok, just went for a warrant for a sw20 and they've come back wanting me to get the front struts checked, the guy was worried their getting/are too soft and wants a second opinion on them from somewhere else (pretty reasonable I thought)
So,
Where is best to get new front struts if they're needed? (Pricewise)
Should I replace the backs as well at the same time?
They're not leaking, so any ideas on what may have caused them to go soft?
I'll get them checked again tomorrow, I hope its not an issue overall but worth getting some ideas now
mcfatty1000
Postby GDII » Wed Aug 28, 2013 5:20 pm
Check pricing with Mark (1I1) our sponsor. He can get you a good price on OEM Bilstein Struts if you do go with new ones.
My current set isn't leaking but are clearly not working as they should. New set of Bilsteins are on the cards in a few months.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby headshotnz » Wed Aug 28, 2013 6:29 pm
^^ What he said. All shocks are line priced through toyota at 160+ or 200+ retail. It doesnt meatter if there for a 1982 shitbox or bilstiens for the MR2 etc.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Grrrrrrr! » Wed Aug 28, 2013 6:38 pm
As for why they are soft... they are probably 20+ years oil, the oil has broken down, the gas has leaked out, and things are generally just wearing out. It'll happen to you too in 20years. :)
Bilsteins from Mark are the best value for money.
Grrrrrrr!
Postby mcfatty1000 » Wed Aug 28, 2013 7:19 pm
Cool - thought so re the reason, just checking there wasn't something I needed to look out for.
Should I get a full set? I'm assuming the rears are about the same age etc
mcfatty1000
Postby Grrrrrrr! » Wed Aug 28, 2013 7:39 pm
Hang on... the guy doing the WOF wants a second opinion on whether your dampers are good or not? How has he got a WOF authority if he cant make that call for himself?!?
Grrrrrrr!
Postby mcfatty1000 » Wed Aug 28, 2013 7:57 pm
Not really - He was going to fail it, but is being nice and letting me get them tested - If I can prove that they're up to spec with a letterhead etc then I'm good (until next time in all likelihood)
I suspect they're the weakest links in the suspension at this point making it seem worse
mcfatty1000
Postby Lloyd » Wed Aug 28, 2013 8:27 pm
So basically it has failed on struts being too soft, and if you can prove otherwise then it's a pass.
Postby mcfatty1000 » Wed Aug 28, 2013 8:41 pm
Pretty much yep.
Mainly, its his opinion that they're too soft but if I can prove they pass via other testing and can prove that, then I can argue from that
Reasonable overall I think, at least its not a, they failed and it'll cost you $xxxx type arrangement
mcfatty1000
