4AGE Bluetop Starts then Dies
Postby spoonza6 » Fri Sep 13, 2013 11:38 pm
AE82 Corolla GT Liftback
Bluetop 4AGE
Start the car, idles like shit, put foot down on gas pedal, dies instantly
Start car, foot on gas pedal, roars into life for a second, then dies
Start car, tap gas pedal on and off intermittently, runs, then chokes then runs
Left car, set alarm...will attack in the morning...
Where do I start?
spoonza6
Postby spoonza6 » Fri Sep 13, 2013 11:39 pm
Oh, quarter tank of gas aswell
spoonza6
Postby 85AW20v » Sat Sep 14, 2013 12:23 am
TPS.
See ya
Simon
85 MR2 20v
85AW20v
Postby spoonza6 » Sat Sep 14, 2013 12:43 am
Replace
Trace
spoonza6
Postby Mr Revhead » Sat Sep 14, 2013 1:16 am
Plug it in?
Checked fault codes?
Postby spoonza6 » Sat Sep 14, 2013 8:40 am
Car broke down while driving home
On my particular car, how do I enable the diagnostic check
I don't think it has that diagnostic box
spoonza6
Postby rollaholic » Sat Sep 14, 2013 8:55 am
might just have the two pin plug, like ae86?
Postby spoonza6 » Sat Sep 14, 2013 8:59 am
Oh, anyone got a pic of which one? Gonna go back to car today n try fix
spoonza6
Postby 85AW20v » Sat Sep 14, 2013 12:01 pm
Vacuum hose could have come off the MAF sensor.
See ya
Simon
85 MR2 20v
85AW20v
Postby Stu- » Sat Sep 14, 2013 12:58 pm
Try un-plugging the TPS to see if it runs better. Vac line to map sensor is a good place to start. Water temp plug connected properly? (Green one on back of head, two wires)
Project Thread
Stu-
Postby spoonza6 » Sat Sep 14, 2013 1:20 pm
Stu- wrote:Try un-plugging the TPS to see if it runs better. Vac line to map sensor is a good place to start. Water temp plug connected properly? (Green one on back of head, two wires)
Unplugged TPS n it did the same ran for few seconds then died
Unplugged map sensor n it did same as above
Water plug connected...
Could it be starved of fuel?
spoonza6
Postby whonose » Sat Sep 14, 2013 1:41 pm
What about the engine start relay? if it fails doesn't the fuel pump stop running?
Click Here to make a clicking noise.
whonose
Postby Leon » Sat Sep 14, 2013 2:12 pm
could be ignitor unit on coil too
Postby spoonza6 » Sat Sep 14, 2013 2:12 pm
whonose wrote:What about the engine start relay? if it fails doesn't the fuel pump stop running?
Where's that? How I get another to check it with to eliminate?
spoonza6
Postby Tagged » Sat Sep 14, 2013 3:12 pm
im not sure if this is even remotely related, but I used to own a skyline that idles like shit and would stall often. Turned out to be a clogged up throttle body. Everything went fine after cleaning it.
Tagged
Postby xsspeed » Sat Sep 14, 2013 3:48 pm
Hey man got your text, but was busy just spotted this now - dont have a TPS but I have a spare coil and ignitor if it turns out to be that
Whats your timing like - possible its been bumped?
Postby xsspeed » Sat Sep 14, 2013 3:49 pm
Postby spoonza6 » Sat Sep 14, 2013 4:20 pm
Not too sure, it died on way home so pulled over n tried to fix to no avail
Am gonna try get it home n...lost on why to do about it for now
Yes I'd like to borrow a few components to eliminate what's wrong with it
spoonza6
Postby matt dunn » Sat Sep 14, 2013 6:30 pm
I would be checking fuel pressure.
Home DIY way is run the return line into a container,
as long as there is fuel flowing out the return there will be enough pressure,
as the regs are ultra reliable unless tampered with.
No flow out means not enough pressure.
Postby QikStarlie » Sat Sep 14, 2013 7:04 pm
+ 1 for fuel pump. or something fuel related at least
QikStarlie
Users browsing this forum: Bing [Bot] and 43 guests
