ae92 steering knuckle/hub interchangeability
Postby ATAl » Tue Nov 26, 2013 5:28 pm
I might need to change the front hubs on my car (ae92 gtz) and if I do I'll grab some new ones from pick-a-part.
Does any know what hubs/steering knuckles are interchangeability with ae92 gtz parts - will parts off normal ae92/ae101 gtz etc fit?
It looks like the part numbers are different on the online catalogue but I suspect there will be some interchangeable stuff regardless.
ATAl
Postby Grrrrrrr! » Tue Nov 26, 2013 7:00 pm
ae101 gt-z are all superslut, so the knuckle wont be interchangable with a mac strut ae92.
Grrrrrrr!
Postby ATAl » Tue Nov 26, 2013 7:21 pm
Good point, any idea about non-gtz versions?
ATAl
Postby molex » Wed Nov 27, 2013 9:37 am
I've got some AE101 Levin hubs on my AE92 levin. No issues...
Remember that the centre bore for your brake rotors will be altered, in my case that's why I did it. Earlier hubs were 54mm, later were 55mm from memory.
molex
Postby Bazda » Wed Nov 27, 2013 5:59 pm
All AE92 hubs are the same.
AE101 Macpherson hubs also fit fine. If you use the AE101 drive flange the disc center bore is 55mm.
Postby ATAl » Wed Nov 27, 2013 6:44 pm
So no issues with gtz driveshafts fitting a normal fxgt hub then?
ATAl
Users browsing this forum: Bing [Bot] and 33 guests
