4agze intercooler enclosing.
Postby 1984FXGT » Sat Jan 25, 2014 12:10 pm
I was told that someone on this forum has plans to enclose the gze intercooler to make it water to air.
Looking at using a oil cooler as radiator for the water but not sure what would the best water pump be? So second question is what pump would people recommend?
1984FXGT
Re: 4agze intercooler enclosing.
Postby Grrrrrrr! » Sat Jan 25, 2014 12:30 pm
You'd want a pretty big oil cooler, you wont have much of a temp difference so you want lots of area to shed the heat.
Pumps.. st205 pump is one of the better options if you can find one cheap. Otherwise you want a circulation pump, not a bilge pump, and marine supply places want your left nut for 12v circulation pumps.
All the information on W2A systems you ever need.
Grrrrrrr!
Postby 1984FXGT » Sun Jan 26, 2014 12:04 pm
What about a heater core from the 82 as radiator for the intercooler if i put a fan on it??
1984FXGT
Postby Grrrrrrr! » Sun Jan 26, 2014 12:17 pm
Thats still tiny.
Thats a factory st205 setup. think more like that size.
Grrrrrrr!
