Strange warning light on jap import hiace 3L D4-D
Postby Timoz » Sun Feb 16, 2014 9:44 am
Hi Guys, need some help on what this warning light mean on the cluster?
It is the one i have circled in red. this light came on yesterday after I changed the oil a week ago after and would only come on 30mins after driving the car.
I made sure to use the correct engine oil, i have used Elf Solaris MSX 5W30 http://www.lubenz.co.nz/Products-and-Services/Products/Product-Family-2/Petrol-Engine-Oil/SOLARIS-LSX-5W-30.aspx
Please advise. Cheers
Timoz
Re: Strange warning light on jap import hiace 3L D4-D
Postby Crucible » Sun Feb 16, 2014 10:03 am
Have you rechecked the oil level on the dipstick?..take it you would have.
Crucible
Real Life Mechanic
Postby Timoz » Sun Feb 16, 2014 10:09 am
Hi, Yep sure did. that was the first thing i checked.
Crucible wrote:Have you rechecked the oil level on the dipstick?..take it you would have.
Timoz
Postby wde_bdy » Sun Feb 16, 2014 10:30 am
Looks like oil level warning, my Dyna van has it come on after about 5 minutes running from cold as the cold oil doesn't drain from the head as fast. Once it warms a little it goes out.
If it is happening after 30 minutes driving maybe check the wire from the sensor isn't touching something as the engine heats up?
Callum
wde_bdy
Postby Timoz » Sun Feb 16, 2014 10:33 am
One guy told me that this indicates the oil level is too high?? Maybe i should go drain some out?
wde_bdy wrote:Looks like oil level warning, my Dyna van has it come on after about 5 minutes running from cold as the cold oil doesn't drain from the head as fast. Once it warms a little it goes out.
Callum
Timoz
Postby Crucible » Sun Feb 16, 2014 12:03 pm
Timoz wrote:One guy told me that this indicates the oil level is too high?? Maybe i should go drain some out?
Reason I asked, the oil pressure and level are on the right of the dash..as you know. But you have checked the level and its ok?as in not overfull?
Crucible
Real Life Mechanic
Postby Lloyd » Sun Feb 16, 2014 12:31 pm
Is it just my computer, or is it really hard to see what that symbol even is?
Postby Crucible » Sun Feb 16, 2014 12:42 pm
It isnt the easiest to see, i can just make it out on my tablet..
Crucible
Real Life Mechanic
Postby wde_bdy » Sun Feb 16, 2014 12:47 pm
Looking at it closer it could be oil temp?
Callum
wde_bdy
Postby Timoz » Sun Feb 16, 2014 1:00 pm
the symbol looks like the low oil level symbol but has a "!" in the middle.
Timoz
Postby Lloyd » Sun Feb 16, 2014 1:13 pm
Definitely an ! rather than a temperature warning one?
Postby Timoz » Sun Feb 16, 2014 1:18 pm
it looks like this
Timoz
Postby Crucible » Sun Feb 16, 2014 1:23 pm
Dont think Ive seen one like that? Level was just a guess..
Crucible
Real Life Mechanic
Postby RS13 » Sun Feb 16, 2014 2:01 pm
Isn't that the oil service required light? Comes on every 10,000km or something. There is a way to reset it yourself, google it.. you put the odo on trip A, hold the button down while turning the key to ON or ACC or something.
RS13
Postby Timoz » Mon Feb 17, 2014 3:51 pm
Problem sorted, it appears that it is the engine oil overfill /service light. the new hiace are very sensitive to oil levels, even it's slightly more than full this light comes on so I went on and drain some oil out. The light haven't came on since the oil level is near the full mark. Anyways thanks for the help guys.
Timoz
Postby kim0663 » Mon Mar 03, 2014 1:53 am
If the oil you used is not low ash, you're going to get diesel fuel getting into the oil, making the oil level rise. 5W-30 grade does not necessarily mean it is correct for the vehicle.
The reason for that light being so sensitive on jap import kd diesels is because they run dpf filters.
I would be draining all of the oil out and putting fresh proper low ash oil in it tbh, diesel fuel isn't a very good lubricant for bearings etc
Seen way too many hiace vans come into work for dpf bypass kits. Same story goes for Dyna trucks too.
Mr2 GT-S
330ci M
kim0663
