Hi all
What would cause blue smoke to come out once at full boost but then it goes away after a second?
Turbo seals/rings? Piston rings? Stem seals?
Shrike wrote:When you did the springs you replaced the valve seals right?
Crucible wrote:Sounds like turbo but generally itll be more white than grey.
Do you have good crankcase ventilation and drain? Only way to be certain is drop front pipe and see if there is oil residue in the exhaust housing.
Mr Ree wrote:You should plumb back your catch can to the intake pipe between the filter and turbo.
The system needs vacuum on it to work efficiently.
I would imagine the smoke would be due to oil pressure being fairly high under the WOT dyno run, and a bit of oil is forcing its way past the turbo seal.
It might do this while you drive but is less apparent.
cat007 wrote:Also I should note that it doesn't smoke at idle when the engine is cold, or when you first start the engine. Only once it's warm does it start to smoke...
