Firewall wiring grommets
Postby wde_bdy » Sun Mar 23, 2014 11:18 am
Anyone found a source for new firewall wiring grommets? On the KP I am re-doing all the engine bay wiring and the ones I have aren't in flash condition. Drivers side is 54mm and passenger for the EFI loom is 50mm (could enlarge that hole to match though). Only ones close I have found are 61mm and in Oz, cant really enlarge the hole that much.
Callum
wde_bdy
Re: Firewall wiring grommets
Postby Rick » Sun Mar 23, 2014 10:06 pm
I ended up going to pick a part and finding what I needed there.
Postby wde_bdy » Mon Mar 24, 2014 7:45 am
Yeah, I've got some secondhand ones from the wreckers but hard to find in the right diameter. Would need to enlarge the holes quite a bit which isn't that easy to do.
Callum
wde_bdy
