93 fxgt no go
93 fxgt no go
Postby Wellyfxgt » Sun Jun 15, 2014 8:32 pm
Hi,
New to forum, bought a 93 ae101 corolla about a month ago, love the car even though its auto.
Has been running fine, then last week it decided not to start all of a sudden, I've read the forum and hired out haynes manuals to sort issue.
Car starts then dies, Ive tested the fuses, relay, checked fuel pressure, bridged diagnostic and heard fuel pump going, removed fuel filter and checked for blockage also cranked and fuel came thru fine.
Got a diagnostic fault code 41 which is throttle position sensor, but arent confident that this is 100% the issue, ive heard that the ecm might have a fault with leaking capacitor caps. I havent checked the ecm yet.
What are everyones thoughts, check ecm... then go from there?
Thanks
Wellyfxgt
Re: 93 fxgt no go
Postby Crucible » Sun Jun 15, 2014 11:26 pm
How much fuel pressure? Have you checked for spark when it stops, injectors firing?
Crucible
Real Life Mechanic
Re: 93 fxgt no go
Postby RS13 » Mon Jun 16, 2014 4:38 am
I'd recommend borrowing another ECU and trying that or pulling it apart and examining the capacitors. The TPS code comes from a fault in the idle switch circuit, if you haven't been stuffing around with it I'd be hesitant to point the finger until you'd tried another ECU.. the lack of codes is normally significant of a fault in the ECU itself.
RS13
Re: 93 fxgt no go
Postby matt dunn » Mon Jun 16, 2014 8:37 pm
The ECU's do give problems in them,
I do heaps of them...
Re: 93 fxgt no go
Postby XS1V » Mon Jun 16, 2014 9:16 pm
ECU would be my guess also, followed closely by AFM which would give exactly the symptoms you have described.
Brad
ST205 Group A Rallye #2363
XS1V
Re: 93 fxgt no go
Postby KinLoud » Tue Jun 17, 2014 10:10 pm
Cambelt - maybe lost a few teeth off the belt and got out of time.
Air flow meter - fuel pump switch failed. Jumper fuel pump connector in the diagnostic plug
Users browsing this forum: Bing [Bot] and 24 guests
