Hey peoples,
What's an acceptable current draw for a car that's sitting, parked up?
Just measured mine and it's 0.25 amps - that's expected?
I pulled fuses from under the dash and nothing changed so it's most likely the alarm?
Cheers.
KinLoud wrote:Adrian - I made a few intelligent guesses along with your current drain into this formula I found!
It explains your current drain almost exactly!
Using the formula I get
Current drain = 0.24266447793776 amps
8460 minutes (6 days) since your previous work session on your car
Working on your car average of 0.5 days per week over the last year.
Amazingly accurate result!
Direct quote from USANYPCA website...
(USA Not Yet Completed Project Car Anonymous)
"Unexplained battery drain in your project car.
Frequent posts/topics on this topic has sent me on a journey of scientific discovery.
I contacted as many members who have current project cars. I arranged to visit them to chat about their project and measure accurately the battery current drain.
Using my Extech 380560 bench micro ohm meter (High Resolution Precision Milliohm Meter (110VAC)
Benchtop meter provides resolution down to 0.01mOhm), I measured the resistance of the earth cable (between battery and chassis). Then with the earth cable reconnected to the battery I measured the voltage drop across the earth cable using my Keithly 2182A Digital Nanovoltmeter
This enabled me to accurately measure the current drain with minimal interference to the circuit.
NOTE - electrical formula I=V/R, I current, V volts, R resistance ohms
During my chat with the project car owners I found out how often they worked on their cars and how many days since they last did any work.
When I got home from my 2 week scientific road trip I put all the data into a scientific spread sheet for data analysis.
I then searched for some sort of correlation between the data.
I was surprised by the what I found!
THE RESULTS
I developed a formula that can explain the current drain
A=(((Last/Pi).Ave)/(Q/k)).C
Where
A (current drain) = amps
Last = minutes since previous work session (prior to session in which current measured)
Pi = 3.141592653589793 (approx)
Ave = days worked on car per week averaged over last year
Q (number of free electrons per cc of copper) = 8.5*10^+22
k (work ethic constant) = 10,000,000,000,000,000,000
C (correction constant) = 1.5
In plain English...
The more recently you last worked on your car and the more often you work on your car the lower the unexplained battery current drain.
Hope this helps everyone"
MrOizo wrote:Could it be that when charging with a 0.25amp draw from the car, this screws with the charger and battery?
