whynot wrote:Gold foil would be good for radiant heat not conducted heat.
gepsk8 wrote:Gizmo gasket work great, got one on my corolla. Drop temperature by 30degrees. Can now touch inlet manifold after driving.
GDII wrote:gepsk8 wrote:Gizmo gasket work great, got one on my corolla. Drop temperature by 30degrees. Can now touch inlet manifold after driving.
When you say 'after driving' what do you mean? I don't have a plastic spacer on my car (bone stock engine) but when I have just finished driving I can touch my intake manifold just fine. After a few minutes it gets heat soaked and I can't touch it. I put this down the air flow through the manifold but when the engine stops drawing air through it, it just absorbs the heat from the engine.
Users browsing this forum: No registered users and 33 guests
