Intake pipe popped off
Postby cat007 » Sat Jun 28, 2014 5:49 pm
Hey all
Noticed today that my intake pipe between air filter and turbo had popped off.
What would cause this?
Re: Intake pipe popped off
Postby Bling » Sat Jun 28, 2014 6:41 pm
Photo of setup might help?
Postby cat007 » Sat Jun 28, 2014 11:44 pm
Bling wrote:Photo of setup might help?
Righto - will get one up in the morn
Hunt
Postby cat007 » Mon Jun 30, 2014 8:28 pm
There's nothing connected to the intake pipe, turbo one end, filter at the other...
Postby Dell'Orto » Mon Jun 30, 2014 9:37 pm
Probably just engine vibration if there is no support for the pipe
Postby cat007 » Mon Jun 30, 2014 9:40 pm
Dell'Orto wrote:Probably just engine vibration if there is no support for the pipe
Hopefully - but it was done up pretty tight IIRC.
What if there was a large amount of compressor surge - would that cause air flowing the wrong way?
Postby Dell'Orto » Mon Jun 30, 2014 9:42 pm
Won't matter how tight it's done up if there's no bead on the compressor inlet to stop it popping off
Postby Stott69 » Mon Jun 30, 2014 9:55 pm
That and remove reducer are put an unrestricted intake on :-p
Stott69
Postby cat007 » Tue Jul 01, 2014 1:06 pm
Stott69 wrote:That and remove reducer are put an unrestricted intake on :-p
hah - yeah I thought about that - although the compressor housing reduces down from 4" to whatever size the compressor wheels inducer is anyway (I think it's 56 or 58mm), so not sure if there'd be much of an advantage going 4" from the filter to turbo?
Users browsing this forum: No registered users and 34 guests
