Too Much Oil
Too Much Oil
Postby ee904age » Tue Aug 05, 2014 7:37 pm
So a friend of a friend has a 2.0L Holden Vectra, has had an oil leak for quite some time and made a road trip to Wanganui last week. Before she left to head home, she topped up the oil. About 5 minutes into the return trip it stared billowing "white" smoke so she pulled over and got it towed back to town, and got a flight home as she had to be at work the next day. Yesterday, after it being towed back from the tow yard (also an auto wrecker) to the friends house, I went and had a look. She was told the towies "mechanic" has checked it out and it had a "blown piston".
First thing I did after hearing about the topping up of the oil and the white smoke was pull the dipstick. It was half full, not half full on the measuring part, but half way up the dipstick! I started it for about 5 seconds to confirm the "blown piston" diagnosis. It ran smoothly on all four so that diagnosis is BS, and didn't smoke at all in the few seconds I had it running.
It was dark and cold so didn't try solve anything on the spot, but other than sounding sluggish while turning over and a littlle "choked" while idling, which I would expect from something with ~4l too much oil, everything seemed sweet.
Google has all sorts of advise as to what damage could have been done, but does anybody have first hand experience about what long term damage could have been done? My next plan is to drain it and refill with the right amount and see what happens.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Re: Too Much Oil
Postby 92mr2paddy » Tue Aug 05, 2014 8:03 pm
they say that catalyc converter gets damaged from it but thats only an emission part so wouldnt worry about that, apart from that im not too sure if it damages anything.
92mr2paddy
Re: Too Much Oil
Postby rollaholic » Tue Aug 05, 2014 8:07 pm
if its running smoothly its probably fine
Re: Too Much Oil
Postby ee904age » Tue Aug 05, 2014 9:18 pm
Thanks guys, just what I wanted to hear!
Mods: Just realised, I should have posted this in Tech section, please feel free to move.
90 SW20 N/A - Sold
ee904age
Re: Too Much Oil
Postby edwagon » Wed Aug 06, 2014 4:46 pm
It can pop the crank seals out and stuff like that but if it seems to work find after draining then I wouldn't think too deeply on it or go looking for problems
8)
edwagon
