Honing cylinder bores at home
Postby cat007 » Tue Aug 12, 2014 2:39 pm
Hi
My cylinder bores are in pretty good nick. You can still see the cross hatching quite clearly, and they don't appear to be glazed.
Is it worth me just getting a honing tool and doing it myself with a drill?
Most machine shops that I've found aren't open in the weekends and I can't really get there during the week unless I take time off work.
Is there much of a difference between doing it at home or getting it done by a shop? Would they have some special tool, or would they be doing it just the same way?
Re: Honing cylinder bores at home
Postby cat007 » Tue Aug 12, 2014 2:58 pm
Scratch this post
$60 to get it done by a machinist and I'll just take a couple of hours off work. I'm sure I have a 'client meeting' tomorrow....haha
Postby Lloyd » Tue Aug 12, 2014 3:38 pm
If it just needs a quick hone then it should be a 5-10 minute job while you wait. It's pretty much just a stone in a drill run up and down the bore a few times.
Postby edwagon » Thu Aug 14, 2014 11:52 am
Totally something you can do at home WITH THE RIGHT TOOL
SLOWLY in a drill
I prefer the 'ball brush' type of hone
The spring loaded 3 legged ones tend to put a taper in the bore if you aren't careful
But for a quick $60 you'd be better off getting a pro to do it if its a one-off type thing
Make sure you clean the bores VERY thoroughly afterwards - hot water and soap with a scrubbing brush - then dry thoroughly and lightly oil to prevent rust
edwagon
Users browsing this forum: Google [Bot] and 19 guests
