Toyota COP igniter signal
Postby Grrrrrrr! » Sun Sep 14, 2014 11:00 am
Is the igniter signal for toyota COPs with built in igniter a 5V or a 12V signal? Just wondering if I have to do any voltage limiting to the COPs.
Grrrrrrr!
Re: Toyota COP igniter signal
Postby Stu- » Sun Sep 14, 2014 11:30 pm
You don't need any voltage limiting. Ign drive from ecu direct to COP. Other wires are 12v supply, earth and tacho output.
Project Thread
Stu-
Postby Grrrrrrr! » Mon Sep 15, 2014 12:48 am
Cheers, that will make life easier.
Grrrrrrr!
Postby Stu- » Mon Sep 15, 2014 12:42 pm
What ecu are you using? I've set these up as both wasted spark and direct ignition before, work well.
Project Thread
Stu-
Postby Grrrrrrr! » Mon Sep 15, 2014 2:21 pm
Link G4 Plugin, but custom harness to support COP on a gen2 3sgte, and will keep the same harness when the gen4 motor goes in.
Grrrrrrr!
Postby Stu- » Mon Sep 15, 2014 6:00 pm
Cool - I've setup quite a few G4's with COP lately. The 2zzge coils are surprisingly good - good strong spark at reasonable boost ~20psi
Yell out if you need a hand with any of the setup
Project Thread
Stu-
