idler for AW11 supercharger belt
Postby pauln » Mon Oct 13, 2014 6:09 am
Hi all , have a bigger crank pulley on my MR2 and need a smaller idler , anybody know what I can use ?
Thanks Paul
pauln
Re: idler for AW11 supercharger belt
Postby thegreatestben » Mon Oct 13, 2014 9:11 pm
Timing belt pulley of some description
thegreatestben
Postby Pelo » Wed Oct 15, 2014 12:25 am
Timing belt tensioner pulley is correct. I went through a lot of these in my old SC with a 14psi crank pulley. The idler needs to be smaller diameter than stock to fit properly. The trouble is that the bearings in the idler seemed to wear out quickly. Maybe the tension from the SC belt was much higher than a timing belt.
I'm hunting through a bunch of old documents on my pc for the part number, but I vaguely recall that I might have used a Ford/Mazda KL or KE timing belt tensioner idler from Repco. It matched the size needed and had a single bolt hole through the centre for mounting.
Take your current one into a parts shop, measure it with calipers, and match it to something available off the shelf.
Pelo
Postby GDII » Wed Oct 15, 2014 9:10 am
Here is your answer. Although you probably already know from asking on the MR2 forum. But for everyone else.
http://mr2.org.nz/phpbb3/viewtopic.php? ... 50#p111955 Parts description
http://mr2.org.nz/phpbb3/viewtopic.php? ... 50#p112040 Parts photo (9 down)
Subaru EJ20 cam belt idler and 3mm spacer washer.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby 85AW20v » Wed Oct 15, 2014 9:36 pm
GDII wrote:Here is your answer. Although you probably already know from asking on the MR2 forum. But for everyone else.
I put that in his post on MR2.org.nz!!
See ya
Simon
85 MR2 20v
85AW20v
Postby pauln » Thu Oct 16, 2014 4:23 pm
Thanks guys used the Subaru one and seems good :D
pauln
