4AGE o2 voltage
4AGE o2 voltage
Postby Vertigo » Sun Jan 04, 2015 10:01 pm
Sup. Anyone know what the voltage of the factory 16v o2 sensor is at stoich?
TVIS just kicked in, yo!
Vertigo
Re: 4AGE o2 voltage
Postby Crucible » Mon Jan 05, 2015 7:19 pm
4 wire O2s are around 500mv @ stoich.
Crucible
Real Life Mechanic
Re: 4AGE o2 voltage
Postby Vertigo » Mon Jan 05, 2015 9:12 pm
Cheers, talking about the single wire narrowband though. It bounces from lean to rich, I know, just trying to track down the crossover point.
Vertigo
Re: 4AGE o2 voltage
Postby sergei » Tue Jan 06, 2015 12:47 am
Vertigo wrote:Cheers, talking about the single wire narrowband though. It bounces from lean to rich, I know, just trying to track down the crossover point.
Bouncing is normal operation, eg it should bounce between 0v and 0.8-1v, it means ECU is trying to get stoich, there is not really a fixed crossover as hysteresis is fairly steep on those. If you get 0.5v on those (and it is not being filtered by multimeter) then it is probably dead, or ECU is ignoring it (but there is slight lean condition?), or both.
Re: 4AGE o2 voltage
Postby gepsk8 » Fri Jan 16, 2015 7:32 pm
On 4age 16v factory O2 sensor waste of space,
O272754663
gepsk8
Re: 4AGE o2 voltage
Postby sergei » Wed Jan 21, 2015 8:11 am
gepsk8 wrote:On 4age 16v factory O2 sensor waste of space,
It depends, if it is AE92 then most likely it is very useful there (square diagnostic plug). On AE82 (round diagnostic plug) probably not so much.
