1N gearbox
1N gearbox
Postby fangsport » Thu Jan 15, 2015 1:17 pm
is the gearbag for the 1N (1.5l diesil) motor specific, or is there another unit ( E/A etc) that will bolt up ?
having trouble tracking a gearbox down to replace one with a suspected broken diff
fangsport
Re: 1N gearbox
Postby Grrrrrrr! » Thu Jan 15, 2015 1:44 pm
What is it in? What is the gearbox code on the build plate?
Grrrrrrr!
Re: 1N gearbox
Postby Stu- » Thu Jan 15, 2015 5:41 pm
Pretty sure they come with a C150 - could just take the bellhousing off (if bolt pattern differs to e series) and slam it onto any C150 starlet box?
Project Thread
Stu-
Re: 1N gearbox
Postby fangsport » Sun Jan 25, 2015 11:06 pm
ok, so completely random.
lifted front wheels off ground, foot on brakes , into gear has drive. back onto ground for some full lock action still has drive. but yet it wouldn't transmit any prior, and has done this trick once or twice before. very quiet in it operation and easy enough to get into gear. confused, suspecting something randomly falling out of mesh ??
box is a C153, do they share final drive with anything else ?
fangsport
Re: 1N gearbox
Postby Stu- » Mon Jan 26, 2015 11:44 am
Ah so in that case any c150 should be fine - at worst you'll need to swap over the bellhousing section of the casings. The ratios will be different but I don't think its something you'd cry about too much.
Project Thread
Stu-
Re: 1N gearbox
Postby 85AW20v » Tue Jan 27, 2015 9:42 pm
Clutch playing up? Or is it auto?
See ya
Simon
85 MR2 20v
85AW20v
Re: 1N gearbox
Postby fangsport » Tue Jan 27, 2015 9:58 pm
85AW20v wrote:Clutch playing up? Or is it auto?
clutch feel pretty solid, it would rather stall the engine than slip when the brakes are applied.
fangsport
Re: 1N gearbox
Postby RS13 » Wed Jan 28, 2015 6:03 pm
CVs are alright? You lose drive if you lose an outer, done it a couple of times.
RS13
