AE115 Carib 4wd switch operation?
Postby matt dunn » Sat Feb 21, 2015 3:55 pm
Hay there,
Who has an AE115 carib with a switch on the dash labelled 4WD AUTO.
Wanting to know how the system works.
Does a light come on on the dash as soon as you press the button,
or do you have to drive a bit for it to come on,
or is there no light at all?
How do you know it is in 4WD mode?
Matt
Re: AE115 Carib 4wd switch operation?
Postby gepsk8 » Thu Feb 26, 2015 11:46 pm
I'm pretty in engages the rear diff in lock type option, cause there full time 4wd if remember correctly from my old work car
O272754663
gepsk8
Postby matt dunn » Fri Feb 27, 2015 7:07 pm
The switch is actually labelled Centre Diff Auto,
and it had a blown bulb in the dash.
So the answer is that the light on the dash should come on as soon as you press the button.
As to what it does there is a solenoid on the centre diff housing,
but dont know much more that that.
Is only a single wire so will only be on or off and have no feedback as to what the diff is actually doing.
Postby 85AW20v » Mon Mar 02, 2015 12:58 am
Put the motor from the DX in it Matt and see which tyres smoke up with the button on or off :lol: :lol:
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Mon Mar 02, 2015 10:31 pm
85AW20v wrote:Put the motor from the DX in it Matt and see which tyres smoke up with the button on or off :lol: :lol:
It's actually the other way around, the motor out of that will end up in the DX, lol
( well the block and crank anyway)
Users browsing this forum: No registered users and 37 guests
