Toyota C60 Close Ratio help
Postby dskd » Tue Jun 16, 2015 10:01 pm
Toyota C60 Close Ratio anyone know the input shaft size and number of splines trying to work out if its the same size as a 4age box ? thanks
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
dskd
Re: Toyota C60 Close Ratio help
Postby touge_ae101 » Thu Jun 18, 2015 7:12 pm
Yes they are the same. Clutches swap over between the two. Only issue becomes bellhousing. Need to use a c56 front half/bellhousing which has a different diff bearing Size to the c60 diff bearing. As for axles you'll need to use sw20 mr2 non turbo axles.
touge_ae101
Postby dskd » Thu Jun 18, 2015 8:03 pm
thanks now to do some pricing
dskd
Postby touge_ae101 » Fri Jun 19, 2015 12:13 am
Would be worth doing some research on the bellhousing to make sure it's that simple. I found an 1zz mrs with a c56 so I'm guessing the bellhousing are interchangeable (wasn't a normal c56 bellhousing/diff bearing arrangement)
touge_ae101
