Ae82 fxgt drive axle
Postby nzbidzel » Wed Sep 30, 2015 3:55 pm
Hey. CVs on my ae82 fxgt nafted out and cant get any second hand ones. Repco only ones that I can find that "sell" and repeatedly asking them is this for a 4age and being told yes they insist its for the fx but no garantee. Its a one piece drive axle compared to the 2piece one the vechicle.
Has anyone installed one of these one piece units. As now as i told repco the cvs stuffed and will completely fall apart when i take out. Now left stranded with no vechicle. cant see how gear flange is removed and need to know if i can remove the gearbox flange end of 2piece to "install" this repco pos one piece.
Susgestions, help, links. Cheers
nzbidzel
Re: Ae82 fxgt drive axle
Postby nzbidzel » Wed Sep 30, 2015 5:58 pm
Never mind bout conversion to remove flange. Stuff that.
What drive axles can i use as a subtitute and do i need other parts to make work.
If it matters its a auto if any difference. When I have cash will be looking at a lsd manual convrrsion at some point but need car on road atm as daily.
nzbidzel
Postby Bling » Wed Sep 30, 2015 7:30 pm
Can't get your CV's rebuilt?
Postby Dell'Orto » Wed Sep 30, 2015 8:42 pm
What exactly has failed, the inner or the outer joint?
Postby nzbidzel » Wed Sep 30, 2015 9:22 pm
Dell'Orto wrote:What exactly has failed, the inner or the outer joint?
Both hub end has play but captive. Gearbox end fell out when i put in the coilovers. The flange of the gearbox end when cv not in wobbles all over too which doesnt make me happy either
nzbidzel
Postby nzbidzel » Mon Oct 05, 2015 8:08 pm
Before I break something attemping this. Anyone know does the flange pop out of trany like the regular non 4age drive axle?
Gonna send off the whole lot to get a new custom one made up. Cheers
nzbidzel
