AE111 Radiator Fan Staying on after AC Removed
Postby 73pixie » Sun Dec 20, 2015 6:28 pm
Howdy Peeps,
Probably been addressed before but would anyone know how to stop the radiator fan running constantly after aircon system has bee removed from a AE111 Levin 4age 20V
From what I can find online a wiring plug possibly can be bridged, if so what color wires or can the AC fuse to pulled?
I see theres a plug by fire wall with four wires and the AC fan plug and pump plugs that have all been disconnected.
also would anyone out there have a spare ECU from a 6 speed BZR Levin?
Cheers,
73pixie
73pixie
Re: AE111 Radiator Fan Staying on after AC Removed
Postby GDII » Sun Dec 20, 2015 7:30 pm
You are right about the plug. It is the AC pressure switch. 2 of the 4 wires need to be bridged but I am not sure what ones, I only know about the MR2 as it only has 2 wires so it's easy.
Possibly pin 2 and 3 Light Green w/ Black stripe and Light Green. See wiring diagram.
http://www.pictureshack.us/images/99608 ... system.jpg
http://s15.zetaboards.com/AE111_Forum/topic/7097988/1/
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby ALES_AE111 » Sun Dec 20, 2015 7:53 pm
On the ECU - my BZ-R is currently using the ECU from a 5 speed BZ-G, so they definitely do work on BZRs.
Apparently there's a difference in the way that it operates as you change gear to potentially reduce the risk of damage to the weaker 6 speed. (but that's all internet information, so who knows how true it is).
ALES_AE111
Postby Ninja25t » Wed Dec 23, 2015 10:21 am
I have a spare 6 speed ECU. Had to buy it myself so would like to recoup some $$, make an offer if you are interested. Cheers
Ninja25t
Postby Flannelman » Wed Dec 30, 2015 9:11 pm
Whats wrong with reconnecting the sensor?
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
Postby GDII » Wed Dec 30, 2015 10:42 pm
The sensor will think it's reading low A/C gas pressure making it stay on anyway.
1990 SW20 MR2
GDII
Postby matt dunn » Sat Jan 02, 2016 8:56 pm
GDII wrote:The sensor will think it's reading low A/C gas pressure making it stay on anyway.
No it works the other way, the switch actually turns the fans on when the pressure is to high,
as hot gas is high pressure.
Reconnecting the switch with no gas pressure will make the fan work as normal.
