What version is the early 4agze based on?
Postby Paulio » Sun Apr 10, 2016 1:22 pm
I've been searching but I cant find the answer im looking for, AFAIK there are basically 3 versions of the 4agze,
The early AW11 MR2 supercharged version running low compression 8:1
The mid aged AE92 GTZ
And the latter AE101 Levin/Trueno GTZ version running (smallport?) high compression
I have found an AW11 as above that has been sadly parked up for way too long, but some parts may be salvageable.
All the pages seem to state the same thing that the gze is in its own category and it doesnt mention what it is based on.
My question is simply what version of 4age is the early 4agze engine based on, would it be the bluetop or redtop bigport? More specically the ignition system cause thats what I want to raid off it first.
Paul
yees booy
Paulio
Re: What version is the early 4agze based on?
Postby thegreatestben » Sun Apr 10, 2016 2:03 pm
Redtop Bigport.
Why do you want the ignition from the mr2?
It's just a distributor and coil. Only AE92 & AE101 had the CAS & coil pack arrangement.
My old mr2 when bought (stock as a rock)
thegreatestben
Postby Paulio » Sun Apr 10, 2016 2:39 pm
It looks the same as yours then. Basically im trying to get parts to get my car going, seeing if they are compatible with my non SC version
yees booy
Paulio
Postby Paulio » Sun Apr 10, 2016 3:07 pm
looking a little sad
aw11 4agze
yees booy
Paulio
Postby Dell'Orto » Sun Apr 10, 2016 7:51 pm
Wow 8O The body must be turbofucked!
Postby Paulio » Sun Apr 10, 2016 9:19 pm
Yea dude I saw holes of rust in the body and didn't want to look any further, shit was getting pretty emotional by then.
Apparently the engine had done 1000KS since a rebuild before having a minor frontal accident.
May still be salvageable tho?
yees booy
Paulio
Postby thegreatestben » Mon Apr 11, 2016 12:22 am
If water hasn't gotten into places it shouldn't then I don't see why not.
If you're being ruthless with removal you can have engine out in like 30 mins :)
thegreatestben
Postby Paulio » Mon Apr 11, 2016 9:28 am
Could be the start to something great..
yees booy
Paulio
