St202 and St215 beams 3s exhaust header swap
Postby xsspeed » Sun May 29, 2016 11:43 pm
Has anyone bothered with this? The caldina headers have the cat's built in which I want to ditch. I have some headers from my st202 beams, difference is the 02 sensor - caldina's is mounted in the middle of the cat's where the celica mounts at the mottom of the 4-2 collector - presumably these are both denso 4 wire 02 sensors so should work?
Re: St202 and St215 beams 3s exhaust header swap
Postby Celica RA45 » Sun Jun 12, 2016 2:44 pm
as long as you have the back part of the st202 beams pipes then the oxy sensor will fit further down
Celica RA45
Postby xsspeed » Mon Jun 13, 2016 3:26 pm
you mean on the 2-1 section? I don't, was thinking of just getting a thread welded into one of the cylinders extractors
