I looked at a late 90s corolla at the weekend a friend of mine has just bought. The previous owner, a poor DIY mechanic had heard that water is the same as coolant in a car and the whole coolant thing is a scam to squeeze the little guy
I've drained it and flushed it heaps run rad clean through it and flushed some more then topped up with coolant with a bit more concentrate at around 60/40 to try and stop it getting much worse.
I think he'll probably need to do the thermostat and the water pump soon too as its a little slow getting to temp and never quite reaches optimum unless its in traffic. But, there's no point in putting the time and effort into new bits unless we can clear the vast majority of the rust.
Any a advice on how to clear it? I've read numerous people online saying they use a 50/50 water vinegar mix and run it for about 1 week then flush and your good to go. I've also hear of people using CLR for a day or so to do it. I've also heard CLR damages seals and aluminum.
What do you guys do? This must be a relatively common problem.
