AE101 rear brake upgrade
Postby Lucky13 » Fri Jul 15, 2016 10:09 pm
Hi all
I have an AE101 Trueno and would like to know what are some good upgrade options for the rear discs and calipers. Are there any other vehicles whose stock gear is a good upgrade? If not, recommendations? It currently has upgraded fronts, Wilwood 4 pots and 280mm Brembo discs.
Lucky13
Re: AE101 rear brake upgrade
Postby Grrrrrrr! » Mon Jul 18, 2016 9:42 pm
Probably a complete waste of time upgrading the rear brakes in a front heavy front wheel drive, they aren't doing diddly squat when you are braking hard. Just go for a more aggressive pad in the rear if you think you can get a bit more effect from the rear.
Grrrrrrr!
Postby Flannelman » Fri Jul 29, 2016 10:29 pm
EBC Green Pads, DP2629 I believe will work. Go to braided lines too.
Caution, I have not got these in my car so I am NOT 100% sure they will fit.
Any particular reason why a rear brake upgrade is wanted?
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
Postby Lucky13 » Mon Aug 01, 2016 12:15 pm
Purely because it's one of the last standard things left on the car. I wouldn't be looking to do it if everything else wasn't so heavily modified... Seems a bit odd to have it still standard. I can't imagine it would make a huge difference but the car is at that stage where only little gains are left to be made.
Lucky13
Postby XS1V » Mon Aug 01, 2016 6:08 pm
When I did my front brake upgrade in the FX race car I found I was locking front very easy with standard rear brakes. Upgraded the rears and it settled it all down :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby Lucky13 » Tue Aug 02, 2016 8:50 pm
XS1V wrote:When I did my front brake upgrade in the FX race car I found I was locking front very easy with standard rear brakes. Upgraded the rears and it settled it all down :)
Sweet. What did you upgrade to? What are you running in the front?
Lucky13
Postby XS1V » Wed Aug 03, 2016 3:03 pm
It was in the AE82, went to GTZ twin pots with yellow stuff pads and the rear was horrible so upgaded that to bigger AE101 set up and matching pads. As you already have those rears I don't know a bolt on upgrade, would personally go twin pot rears in your case, will need to faff around to make it work but there must be a kit somewhere.
Brad
XS1V
