Temp sensor help
Temp sensor help
Postby blobbi » Sat Sep 10, 2016 6:28 pm
Could you please help me identify which temperature sensor this is on my caldina 3sfe?
The plastic housing to connect it has broken and I want to replace it but having problems working out exactly which one it is.
blobbi
Re: Temp sensor help
Postby GDII » Sat Sep 10, 2016 8:49 pm
If the wire is a single yellow with green stripe it will be for the gauge. It has no affect on an of the other systems.
PNC 83420 http://jp-carparts.com/toyota/partlist. ... 6&fig=8401
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby sergei » Tue Sep 13, 2016 9:38 am
It should the same across all toyotas of that era. Plug might be different.
You could also buy new one from Toyota or Partmaster.
If on budget just go to any pickapart and I bet you will find what you are looking for.
This sensor is for the temperature gauge.
