speakers in AE111
speakers in AE111
Postby deaf_rattle » Sun Aug 27, 2006 12:08 am
I have got a couple of pairs of 6.5" coaxials to go into my girlfirends levin while shes in the uk.
i took the stock speakers out of the rear locations and there are no holes for putting aftermarket speakers in.
Im thinking i have a few options
1) make a spacer that bolts into the tray and uses the stock bolts to secure it, then mount the speakers into the spacer
2) use some sort of sealant/glue to mount the speakers (not liking the sound of that, but it is the easiest solution)
3) drill holes from in the boot up, so i can screw the speakers in like they should be mounted (probably the most time consuming idea)
What have other people done?
Also there were some pics floating around of spacers for the front, so 6.5"s could go in the doors, has anyone got some pics i can look at?
Postby blackie » Sun Aug 27, 2006 7:18 pm
Make a MDF spacer.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Postby john_l » Mon Aug 28, 2006 1:08 pm
6.5s fit in the doors, but the door panels can be a biotch to get off the first time... I just made up MDF spacers for the fronts, sorry no pics taken.. The original hole is around 7 or 8 " big.. so you def need spacers...
As for the back i have no idea, i have 6x9s on spacers... getting rid of them soon so i'll probably be in the same vote as you soon..
Churr
john_l
Postby CozmoNz » Mon Aug 28, 2006 1:16 pm
front had spacers in my ae111, simple mdf ones, and the back had a board with spacers for 6x9's (cringe)
just fit 6's to the rear....
yay the joys of a neighbour of to much spare time (ILL FIT IT!) he screams...
i so should have done the wiring though lol, so rungi.
Rayne For President!
CozmoNz
