Alarm install help...
Postby Ice block » Tue Aug 29, 2006 7:31 pm
Just put a uniden alarm in my Bongo , Does anyone no where the indicator relays are ??? OR are there none ?? I've found 3 relays and a flasher unit behind the glove box . Can't see anything else .
Also , the immobilisers do i just hook up off the steering column ignition wires , or in the engine bay itself .
Cheers all
Ice block
Postby blitza » Wed Aug 30, 2006 1:07 am
problem #1, you brought a uniden.
Problem #2, you should have just pulled the curtains on the bongo
you normally don't need to find the relays themselvs, just use the wiring that goes down the steering collum from the indicator switch
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby t0ms » Thu Aug 31, 2006 8:20 pm
problem 1... indictaors. dont go to the relays go to the column and grab thegreen with black trace and green with white trace wires. each should blink 12volts on a multi meter in time with the indicators (ones left the others right) connect to these.
problem 2 immobilisers. unless you really know what your cutting do you really want too???? immobilisation depends on a lot of things. petrol or diesel? high current or low? manual or auto?
t0ms
Postby Ice block » Sat Sep 02, 2006 10:26 am
Cool thanx for that .
Ice block
