Tilt sensor
Tilt sensor
Postby gleem » Tue Jan 16, 2007 9:40 pm
I've just had a avs s5 alarm installed seems to go ok but when you rock the car or jump on the towbaro make it go up and down it does nothing, is this right or should i take it back to get looked at, on the description it said it had tilt and glass break sensor so i hope i havent been ripped off!
Thanks
gleem
Postby big_boy » Tue Jan 16, 2007 9:47 pm
there is a sentivity adjustment on the brain but failing that there not very sentsitive to getting shaken well mine isent any way
big_boy
Postby Mr.Phreak » Tue Jan 16, 2007 9:48 pm
Jack up your car and take a wheel off, if you can....then it's not working
Mr.Phreak
Postby AE82 FXGT » Wed Jan 17, 2007 10:34 pm
Yeah I think the tilt sensor only works when the cars at a certain degree, if your car is being towed etc...
AE82 FXGT
Postby Deno » Fri Jan 19, 2007 6:53 am
Tilt sensors set to 0 degrees when you arm them. The car has to be tilted approx. 3 degrees in any direction to set it off. Rockig wont work, it has to be tilted then held there to stop false alarming.
You're just jealous the voices are talking to me!
85 MR2 NA faded red
86 MR2 Supercharged
90 Starlet GT (sold)
93 AE101 Levin parts car (PM if you need anything!)
97 Carib Sprinter (sold)
Deno
