Couple questions....
Postby FST4RD » Sun Jan 11, 2009 9:03 pm
I have a 2 channel amp at the moment running the sub and it does a pretty decent job....
I now want to buy a 4 channel amp to run the front and rear speakers inside the car.
At the moment I'm running a cheap sony explode head unit with 1 x rca output and going to upgrade.
Question is do I need to get a head unit with 3 x rca outputs or can I get one with 2 x rca's and run the rear speaker rca's and then split them to run the sub amp and to the 4 channel amp for the rear speakers? Is that ok to do that?
Also anyone have any idea the factory front speaker size for a 1992 Mazda familia sedan with wind up windows (if that matters)?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Emperor » Sun Jan 11, 2009 9:18 pm
Your amp should have an output RCA, just run a RCA from one amp to the other?
Emperor
Postby FST4RD » Sun Jan 11, 2009 9:27 pm
Only got 1 pair of rca for input only....
FST4RD
Postby jakesae101 » Sun Jan 11, 2009 9:39 pm
you need a headunit with 3 sets of pre outs with front pre outs rear pre outs and sub out the front and rear pre outs goto the 4 ch amp for the speakers and the sub pre out going to the 2 ch for the sub
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Bling » Sun Jan 11, 2009 10:39 pm
Depends how fancy you want to get..
The other way you could do it (to saving replacing headunit) is buy a 4 channel amp with RCA output on it.
Then you just piggy back the 2 channel off the 4 channel amp and go roll the streets :lol:
Postby neo » Mon Jan 12, 2009 12:58 pm
by one rca, I assume you mean one pair of rca's.
Just get a splitter, and adjust the gains to suit. After-all, that is what they are there for.
neo
Postby mr30%jr » Mon Jan 12, 2009 2:07 pm
you can quite happily run on all 3 ways.
1 set "with rear output" just use millions of Y splitters :P
2 set "front and rear/sub" leave the headunit on rear output and Y split to the sub and rear channels.
mr30%jr
Postby FST4RD » Mon Jan 12, 2009 5:23 pm
mr30%jr wrote:you can quite happily run on all 3 ways.
Oh sweet :)
I wanted to do it this way, front rca output to the 4 channel amp, rear rca output split into 2 and then into the 4 channel amp and the sub amp :D
Good to know you can
FST4RD
Postby Stott69 » Mon Jan 12, 2009 10:15 pm
or if your 4 channel has high input you can wire the speaker outs of the head deck to it, and then leave your current sub set up useing the rcas
Image jzs147 Aristo money pit
Stott69
