Santa's Racecar Alarm
Postby Infinite » Fri Feb 17, 2006 8:11 pm
small box with your fuel line runing thru it :) make it look like its being used and then hide the alarm in it...
Lots
Infinite
Postby Dragger_Dan » Sat Feb 18, 2006 2:03 am
Hold on, why not a shot gun shell primed by the door opening? Could be a lot of fun.
Dragger_Dan
Postby loudsir » Sat Mar 11, 2006 4:45 am
Run the wires thru the rollcage - drill a hole thru the floor and mount the brain and backup battery under the car in the shallowest metal box you can - last place you would be looking for an alarm. It would probably go off if you crashed it though!
loudsir
