Blackrazor wrote:Ah yeh, forgot Clarion. Shame there isnt much in the way of a dealership in NZ anymore
I saw what appeared to be a rep vehicle plastered up with Clarion logs all over it a couple of days ago.... wonder what that was all about.
pyro_sniper2002 wrote:SnoozinEuro wrote:Foryou seem to make pretty sweet headunits.
Then why dont you buy one
pyro_sniper2002 wrote:It wont be anywhere close to 50x4, Max ratings are the marketing devil mmmk
No real difference between twin RCA and single 3.5mm line plugs, SQ-wise. Not on iPod feed anyway.rowan wrote:Mainly use ipod so its a shame that most other brands need an adaptor to run aux or they have the front input single line in, which i do have questions about quality "someone shed light"? BR?
Yep,it can effect the airflow from the coil vent and lead to overheating or changes in sonic response. General rule is to try and stay at least 25mm away, preferably 35 or sorowan wrote:Oh and BR thinking of making new enclosure for sub is it a bad idea for the back of sub to touch or be very close to the inside of a sub box and why? cheers Rowan
RedeviL wrote:Personally I wouldn't touch any headunit other than Eclipse.
Clean, simple design. So damn easy to use and awesome internal hardware.
I tried some of the other high end units out there, but got so turned off by usability, look and lack of sound quality on the whole.
Eclipse also keep away from crazy high power output on the unit, instead opting for external amping as you should do anyway. 5v and 8v pre-out standard on the units worth looking at.
Pure sex imo.
