140* dbs in ae92 fxgt?
Postby Blackrazor » Wed Oct 26, 2005 11:58 pm
Take a looksie at this then ;) Download HERE 2.8MB
And for the record, those arent even ultra-high end subs... we're looking at bringing Ascendant in... performance, SQ and price wise they sit between the Adire Koda and Brahma lines :)
Boring Sig
Blackrazor
Postby nmemr2 » Thu Oct 27, 2005 1:42 am
fx'dwagon wrote:and you will never get 140 out of it sorry but its the truth
yea i hate to say it but i think it would be cheaper and less work to ditch the 10's.
thay have such a small power rating, buy better 10's if you like 10's but with a higher power rating to start. also make sure you have more than enough power running from a good amp to them and have them in a good box and you might manage it.
i recently had my car tested with termlab and got 129 (128.9) DB
i am running 2X12"S that are 500 rms and the amp pumps a massive 1000watts max into them. my car is small so it makes big compression.
unfortunatly to make big numbers you need a big setup and make sure it is wekll designed.
there are heaps of good ideas in here its just the time and money involved in setting them up properly
SW20, a work in progress for 2 years now, all i need to do now is work on it
nmemr2
Postby GGnz » Thu Oct 27, 2005 11:21 am
My corolla hatch used to be running approx 125db. Now with the new setup in my Trueno its 130db (using same amp, just different sub)
GGnz
Postby method » Thu Oct 27, 2005 3:08 pm
I got 134.1 with one 10" sub in a stupidly big abc box tuned to 30hz, the sub was playing a 67hz test tone so the tuning was way off. Also my cars resonant freq would be something else. Im sure 137+ would be achievable if i had set it up right.
PICS UPDATED DAILY
method
Postby DeeCee » Thu Oct 27, 2005 5:11 pm
we recently hit 147.8 with 2 12" subs and 2 amplifiers ;)
GT Four Adovansu
DeeCee
