Rona73 wrote:also i like their glass break sensors, to me thats te only decent break in sensor you can get because it doesn't pick up false alarms like shock sensors do. if you have a shock sensor and your alarm keeps going off because even the slightest bit of noise from an exhaust sets it off, that means other people like your neighbours etc stop taking interest if they hear your alarm going off.
really? you've never tapped your keys on the glass of a car with a glass break sensor..........
A PROPERLY set up shock sensor is good for deterent. lots of would be theives still do the tyre kick test but it should be set so a decent boot to the tyre will only trigger the pre warn
Rona73 wrote:they have a second button on the remote that can be used for other things
as do 99% of the alarms on the market
mongoose m 60 and m 80
dynatron 3 and 7 series
avs as stated above
even unidens
etc etc etc
i still have a viper 800 from my last car which has 7 available outputs. i used to run window automation (up and down controlled from remote), boot pop, stereo on and flash headlights.... but it was about a 1000 dollar alarm when i got it a few years back[/quote]
