Altezza headunit replacement
Postby bigfut » Wed Sep 07, 2005 7:42 pm
Am going to replace the headunit in the altezza, and wanted to check, is it a simple plug and play, or do these have little mini amps on each speaker like I have heard? Would this mean running new wires? Any help appreciated
http://toyspeed.blakjak.net/profiles/profile.php?id=1702
The Harder You Fall The Higher You Bounce!
bigfut
Postby DeeCee » Wed Sep 07, 2005 7:48 pm
for no particualr reason i was on teh altezza forums today.. they seem to have a decent amount of info regarding aftermarket installs:
http://forum.altezzaclub.org.au/index.php
also, speakers don't have mini amps on them to power them.. well none i've heard of.. most likely capacitors for x-overs but thats about it.. you shuold be fine in installing a new headdeck in :)
GT Four Adovansu
DeeCee
Postby pidge » Wed Sep 07, 2005 11:23 pm
Wander down to a car audio shop and buy a wiring harness adaptor for your make and model of car (I've done this twice) - it plugs into the factory wiring for the speakers, accessories power, battery power ("memory"), power antenna etc, and provides wires for you to connect to the wires from your headunit. Much nicer and neater, and leaves the factory wiring intact if you decide to put the factory unit back in for some reason.
Also make a trip to Jaycar or DSE for a soldering Iron (or borrow), solder and heat shrink tubing, if you don't have any, and wire strippers (unless you can be real careful with a box cutter or craft knife). It's tedious and you have to triple check that you've got the correct wires connected.
It would also pay to run a separate 16 or 8 gauge wire for power, with a fuse at the battery end, for the "memory" power to the head unit (which is used as the main power source - the accesories "power" is just used to tell the head unit to switch on. (I think!)
If you can't face that, someone on the board might do it for you in exchange for a quantity of their favourite beverage - or just take to one of the Pros - at least you'll get a warranty on their work.
pidge
Postby Muzzie » Fri Sep 09, 2005 10:28 pm
DeeCee wrote:for no particualr reason i was on teh altezza forums today.. they seem to have a decent amount of info regarding aftermarket installs:
From what I gather the Bosch sounds in Audis etc, the headunit has no internal amp and each speaker is indiviudally amped so it's possible,
My dads MS8 was like that for the rear speakers as well.
Muzzie
Regular Poster
Postby turbo tezza » Fri Sep 09, 2005 10:40 pm
No, the altezza does not have separate amps for each speaker.
turbo tezza
