sony head unit,
sony head unit,
Postby strap-on » Sun Sep 25, 2005 4:04 pm
i have three wires that i cant work out a blue one a light blue one and a blue with a white stripe anyone know what they are?
strap-on
Postby samlloyd » Sun Sep 25, 2005 4:53 pm
Blue = ellec aeiral
w/stripe = remote for amp
light blue could be for illumination. Just google sony wiring diagram
*will not be held responsible for advice given
samlloyd
Postby Lloyd » Sun Sep 25, 2005 7:35 pm
Pretty sure light blue is an ATT wire. Check the other two to be sure, aerial one will only be on with the radio and the other should be live all the time the unit is on (for amps)
Postby samlloyd » Sun Sep 25, 2005 11:16 pm
Have a go earthing the possible antena(sp) wire, some of them will make a noise when its earth( mine did)
samlloyd
Postby strap-on » Mon Sep 26, 2005 12:01 am
got it
Blue was arial
light blue was att
blue with stripe was system remote control
had a bit of a hard time getting the arial to work, i thought the cable that it was was the earth cable, i got it going only to find its broken, the motor spins but the arial wont go up or down,so i gotta pull it out
strap-on
