Sub making odd noises.
Postby GGnz » Sun Oct 09, 2005 8:08 pm
It seems kind of wierd but lately I keep getting some form of feedback on my sub. Random low bass notes that arn't in the music!?
Why could it be doing this. I havn't checked the wiring yet but its been fine for about a month now... :?
GGnz
Postby GGnz » Sun Oct 09, 2005 8:35 pm
Forgot to mention but, you can actually only hear it when you have the stereo on quiet.
GGnz
Postby Snoozin » Sun Oct 09, 2005 9:51 pm
By "feedback" do you mean a hum? And is it when the car is running?
First things first, check ALL your earth points - ie. make sure the amp is properly earthed, the h/u is properly earthed, and the earth points for both the battery to chassis and engine.
Snoozin
Postby GGnz » Sun Oct 09, 2005 10:26 pm
Not always a hum. Only occasionally and seems to be when the car is running. Will check em tomorrow.
GGnz
Postby Alex B » Sun Oct 09, 2005 10:36 pm
Only when car is running?? Yep more than likley an earthping problem.
Postby GGnz » Sun Oct 09, 2005 10:46 pm
Grrrrrrrr! I hate sounds!
GGnz
Postby Alex B » Sun Oct 09, 2005 10:49 pm
Well do it once do it right i say 8) , Bigger earth wire wouldnt hurt, 8G a bit small and find a decent earth, if its a painted part of the chassie, remove the paint under the earthing point too.
Postby Blackrazor » Sun Oct 09, 2005 11:20 pm
Probably have the gain wound up too high for a start.
Boring Sig
Blackrazor
Postby Mr.Phreak » Sun Oct 09, 2005 11:40 pm
But winding the gain up makes it louder Guv'na!
Mr.Phreak
