solution ?
solution ?
Postby LEV_101 » Sat Oct 15, 2005 9:11 pm
hey there.
i have recently changed my headunit and found out that there is no pre-outs to run my amp :( . is there anyway which i can do to run my amp for my speakers.
thanks guys
LEV_101
Postby Muzzie » Sat Oct 15, 2005 9:31 pm
The amp may have speaker level inputs. You just put the speaker wires onto the amp terminals and then it gets it's signal that way.
Not all amps have them though, so you may have to not use an amp, or get a new one :)
Muzzie
Regular Poster
Postby Lloyd » Sat Oct 15, 2005 9:32 pm
Probably best to get another headunit. If your amp doesn't have high level inputs then you can get a converter type thing from Jaycar that you plug your headunit speaker wires into and it outputs them as RCAs so you can still use an amp. DSE might even have them too, have a bit of a search around.
Easiest would be a new headunit though
Postby LEV_101 » Sat Oct 15, 2005 10:54 pm
thanks guys , i think i will just leave the amp out for now . :(
LEV_101
