help!
help!
Postby Emperor » Fri Dec 30, 2005 7:39 pm
argh, ok we installed my sub and amp, all hooked up to the battery, etc
but neither works.
The green LED on the amp doesn't show up, and nothing goes through the amp.
It's a 4 channel NBN amp, where should everything be plugged?
So far, we've done this -
Sub plugged into channel 1
RCA's from Headunit plugged into IN2
Power is getting to the amp, just the amp isn't working..
Help? :cry:
Emperor
Postby 86_rolla » Fri Dec 30, 2005 7:47 pm
remote wire to headunit?????, u need to earth the amp, direct power wire to the battery, rca's from amp to h/u and remote wire also from amp to h/u
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby Emperor » Fri Dec 30, 2005 7:48 pm
all that's done
Emperor
Postby Mr.Phreak » Fri Dec 30, 2005 8:00 pm
If you've got +12V on both the power and remote terminals on the amp, and its still not going, check the amps fuse(s)......if they're good, I'd be worried about the amp...got a mates car you can try it in??
I'm assuming the green led is a power light, and not a protection warning etc?
Mr.Phreak
Postby Emperor » Fri Dec 30, 2005 8:01 pm
red is protection, green is power
im gona try a mates amp tomorrow
Emperor
Postby 86_rolla » Fri Dec 30, 2005 8:12 pm
yeh id just say check all the connctions esp the rca's maybe one mighta popped out when putting ure h/u back in?
Ex cars: 2E corolla
86_rolla
Postby Emperor » Sat Dec 31, 2005 1:56 pm
ITS ALIVE!
Was just the remote lead from the head to the amp, fixed now!
Emperor
Postby vvega » Tue Jan 03, 2006 9:06 am
Emperor wrote:ITS ALIVE!
im sure someone told you to check that............
jeezzzz
v
vvega
Postby Emperor » Tue Jan 03, 2006 10:45 am
why do you think its fixed? I checked it :D
Emperor
Postby vvega » Tue Jan 03, 2006 11:39 pm
Emperor wrote:why do you think its fixed? I checked it :D
good man :D
glad to hear its sorted :D
v
vvega
